Topic: Test your knowledge! (Read 42948 times) previous topic - next topic
Re: Test your knowledge!
Reply #270
Yes they're below the nuts, one of which you can just about see glinting in the image below, situated at the bottom of the box.
Act as spacers for the light metal plate to prevent it being over tightened / restricting the movement of the greased ball / socket at the end of the gear stick.
Reply #271
Something similar - this time not a part in its own right according to 7zap... but is a component of a another item.
I've cleaned these up, I think they would've been yellow zinc'd originally.
Had to spend the 50p.
Reply #273
It was those or the bong...
Reply #274
A clue saying as I'm nice... You should be getting very hot with you next guesses!
Reply #276
That's them... well done!
Reply #278
Can't say I've seen them before
Reply #282
Rear hatch spoiler?
Reply #283
Looks bit like grommet the the rear window heater wire goes through.
But if easily lost it ain't that
Reply #284
Oh it's not the fuel filler flap rubber stop is it?
