Topic: Test your knowledge! (Read 42948 times) previous topic - next topic
Re: Test your knowledge!
Reply #285
First thoughts were you've a tick, then zoomed in... is it one of the glove box lid buffers?
Reply #286
Sorry all very inventive though , you should check your cars , L90 is going to have an apoplexy trying  to find them …..
VW list it part number 443 877 ……………. bugger can’t read the rest
Maybe the heavens for guidance ?
Reply #287
I think I know what it is, but more to the point, what are you doing up at nearly 2am??!
Reply #288
Are these on the sun roof surround when you open the roof around the wind deflector area
Reply #289
I hope so, as that was my idea too!
Reply #294
No that’s right. I just had a brain blip for a moment and thought they were come side up. But thinking about it that makes no sense.
The little hole helps to fit them , push something small in the hole to help bed it
Reply #295
Courtesy of @PWardy ...
Reply #297
ah crap, it's another familar item I know I've had my hands on. Just where was it? I guess that's the draw back on knowing nearly every nook and granny of the things.
For scale, if I'm correct it's a 8mm spanner for the bolt head?
It's on the car finger tight at the moment, didn't have 1/4 drive set available.  I'd guess 6mm bolt head.
Edit. Tightened it up today, hex is 6mm.
Reply #299
I would have thought it was a coolant hose clamp of an early model
