Topic: Test your knowledge! (Read 42805 times) previous topic - next topic
Re: Test your knowledge!
Reply #30
Is it a circlip, can't quiet figure it out.
Reply #31
The clues don't help me either
Reply #32
is it the clips holding the pedal pivots?
Reply #35
Argggh! You ********, ********, ******** sadist *******!
For ***** ***** tell me now, ******* ******** going insane.
Hours on the ********, ******** interweb ********* so very tired, pitys sake!
Reply #36
Yeah, my thoughts too.
I don't know what's worse, not knowing or how much I'm going to kick myself when he finally tells us!
Reply #37
Sorry guys I thought that would have been easier. I guess it depends what jobs you do and I've done this one a couple of times now.
You might just be able to see at the bottom right of the pic, they are located on the inside of the air vent and give the satisfying snap when you push your air vent back into place.
They snap onto the little lugs in the vent surrounds
Reply #38
So, let's go again
This one's even got a part no, but I don't think you can make it out
You're likely to only get this is you're got (or had) a totally unmolested original example as it's one of those items that really isn't needed so is unlikely to get replaced if it's ever lost or if you're working on that particular area.
Enjoy.
Reply #39
Bet mine where long gone then
Reply #40
Exhaust buffer?
And I only think it's that because I was checking out systems last night and noticed something similar on a schematic... kismet
Reply #41
To be honest, I'd never had got that one!
Is that the back box between the two rubbers?
EDIT - Beaten to it!
Reply #42
No 5 I think...
Reply #44
Never seen that either
