Topic: Test your knowledge! (Read 42115 times) previous topic - next topic
Re: Test your knowledge!
Reply #420
Theft of ECU?
Reply #422
Is it to stop the bonnet release being activated through the grille?
Reply #425
That's it, rivets under the slam panel.  Keeps screwdrivers and dirt out:
Risk of theft was high during the 90s so I didn't mind the inconvenience of drilling a hole through it if my bonnet release cable failed.
Reply #426
That anti-thief device was a smart move. For some un-known reason VW have put a plastic joint in the bonnet pull on the mk3 Caddy which regularly fails unlike the Golf
I'm thinking what obsure item I can find as the next clue.
Reply #427
Hope everyone had an enjoyable Christmas / break.
I couldn't find the part I was looking for so here goes...
Reply #428
The one on the right is the ISV holder?
Reply #429
The other I believe is also bolted to the head.
Reply #430
Correct. But what's the one in the middle!...kidding!
Reply #431
Getting warm. But what does it do?
Reply #432
Secures warm air deflector plate?
Reply #433
In case I've the name wrong!
Reply #434
Correct. That example is remarkably intact!
My original was full of holes!
