Topic: Test your knowledge! (Read 33812 times) previous topic - next topic
Re: Test your knowledge!
Reply #45
Should've added something to the image to give you an idea of scale - it's roughly the diameter of a 5p coin.
Reply #46
Tim, I knew I'd got my priorities all wrong when I said I'd do the wahing up.
No wonder progress on the golf is so slow!  :D
Reply #47
Part of the Rear brake bias setup, spring connects round it
Reply #48
Spot on, I'm running out of things that might be harder to guess!
Reply #50
Mine, like the regulator itself was well past it and had warped / split.
Appears to come in two distinct parts, the plastic outer bit (5) and a metal inner (4).
I was able to salvage the metal part and you can get the plastic part on it's own from Deutscheparts for £4.79 inc. postage.
Just had another Google and this Dutch one's popped up, looks the same thing but includes both parts for not much more if you need the whole thing -
golf1onderdelen
Reply #51
Reply #52
The triangular piece is on the opposite end of the spring to the mystery part that's out of sight, behind the bolt and washers in the piccy -
Reply #53
You lot know your MK2's too well, so this is likely a penalty kick but I'm running out of ideas.
Reply #54
Dust covers for the hub on the rear axle
Reply #55
Ah I kept the bracket end bolted to the bean and did it from the side with the car on stands so didn't really get a close look at that end. I just knew I had to clip the spring over something that's why I didn't recognise it.
Reply #58
Reply #59
 :-X
