Topic: Test your knowledge! (Read 42113 times) previous topic - next topic
Re: Test your knowledge!
Reply #465
Reply #466
Worth a try... it helps secure the warm air deflector plate to the intake manifold, 26B in the schematic.
Reply #467
I wondered where that fitted.
I have 26C and I'm sure I have a 26B lying around somewhere which I didn't know where it went.
I decided not to replace the manifold ducting because the car works absolutely fine without it (I recall reading a Rubjonny post). But appreciate mine isn't quite "factory".
Reply #468
recently, i found a "Female fixing grommet to accommodate the male clip that secures the protective door sill covers to the body." on heritage parts:
it looks somewhat similar to the part, which origin we where also going to sort out, i guess:
the sun came out and helped a little :-)
one square of this math-paper, on which i have place the part on, is half a centimeter.
some measures are: height 13 mm, disc-diameter 23.5 mm, bolt-diameter 15.5 mm.
but i can not find it on the car, either.
could anyone give me a hint ?
Reply #469
I think they go on the leading edge of the rear arches down by the sills. I think they were white from the factory. They are redundant on my car so they are filled with silicone. The arches on a gti also provide chip protection.
Ill take a look later, the arches are off at the moment.
Reply #470
Curiosity got the better of me, three each side filled with silicone (sorry about the rubbish picture).  Could they be the Heritage bungs?
Edit, had a thought, the rubber chewed up bungs with cavity wax in them; if that is what they are?  Reinforced cavity, can be used as a jacking point, on the floor pan next to the front sill jacking point.  That has bungs in it that get messed up by jacks.
Reply #471
thank you, but i guess they aren't it.
anyway, i'm able to literraly uncover the heritageparts part now.
it's all below the rockerpanel.
heritage gave us a little hint (fitting info).
they said this pin would go in those grommets:
i saw the pin when i levered off one side of the rockerpanel (after removing one or two screws).
one side goes into the grommet, the other in a clipping rail of the rocker panel.
now i have a guess about part, which i made a picture of.
it might be a blind for, for whatever reason, unused fixing holes.
they seem to be a little chewed up on the top, but the cavity wax hasn't peeled of.
i can not find any such bungs from below.
cause i already have a broken rockerpanel,
im a bit reluctant about ripping off the whole part just for looking,
but maybe there are some restoration pictures on here,
which may show possible locations. i will take a look.
Reply #472
i know where this belongs:
you, too ?
Reply #473
its a part of the front door.
Reply #474
i came across it while swapping the wing mirror (including case and arm).
Reply #475
the part goes from the outside into the hole for the top bolt
of the wing mirror holder.
as from wingmirror.net:
it seems to be a guide, but since there is a frame,
i do not exactly know, why it is necessary
and then why there is just one part, but 3 bolts.
it also does not stick well in the sheet metal hole.
