Topic: Jetta Water Leaking Into Passenger Footwell (Read 2200 times) previous topic - next topic
Re: Jetta Water Leaking Into Passenger Footwell
Right so I've poured around 500ml of water down that drainage hole in the sunroof and its come out the other end l, no water in the footwell and no drips at all.
Makes things even more confusing!
No that’s good, means you inner roof skin around the sunroof drain tubes is solid. That photo of the bottom of the A pillar is you only problem . Run a hose pipe over that lower corner of the windscreen and that rusty patch where the A pillar meets the inner wing and watch it come in through that seam.
